Can't eject my usb external !
Caporegime
8 Sep 2006
On Ocuk
Starting to get a little annoying now but my seagate external the only way for me to eject it(remove) is by restarting the system. As soon as i copy anything to it or load a few dos games from it, basically use it i'm unable to eject as it basically says it's still in use by something. Yet clearly using the unlocker app or checking processes there isn't anything.
I've set it to the correct settings in hardware as well ie not performance mode!
Can the usb hard drive be safetly left plugged in the entire time the system is on as if it's an internal drive and then shut down when the system shuts down?
EDIT : http://blog.tune-up.com/windows-insights/whats-blocking-your-external-usb-hard-disk-or-thumb-drive/
n/m
