I need to replace both rear indicators on my 2005 Hornet F4, however am struggling to find an exact replacement:
I'm not sure if these are even stock as all my searches on M&P etc. have brought up larger indicators with a shaped base rather than a round base.
They have on them:
H21W
11 12
50R-000141
ST-034A
Not sure if that's of any help.
The bigger ones that are coming up when searching for Hornet do look correct as they are the right shape to fit on the bike without needing the spacer, but I would quite like the same as the one shown above. The Honda replica ones are also expensive.
Any ideas?
Thanks
They have on them:
H21W
11 12
50R-000141
ST-034A
Any ideas?
Thanks
