- 16 Oct 2007
- Worcestershire
Just done a new rebuild, total change from AMD to Intel CPU & board
Win XP SP2 32bit
I reused my old case so fitted the original mobo etc in another cheapo case. I intended to do a file transfer but something went wrong as my old setup won't recognise my sata drive anymore altho it does with the IDE drive & no problem there.
I tried the 74 gig Raptor sata drive in my new PC & selected to delete & reinstall windows. I got as far as the deleting bit but it said it couldn't recognise a proper partiton or similar wording & there was only 8 meg left so couldn't install on that & I can't get any further apart from a reformat which I
don't want to do until I get the info off
Tried to load the drive in safe mode to delete all its drivers but it flashes a blue screen( to quick to read it) & restarts over.
My best bet is to try & get my old PC to recognise the drive
Is there a way to make the mobo ( Asus A8V)recognise the drive by using a floppy or anything? Is there a way to access or repair the drive in my new PC? It recognises it but if I load windows on my other drive it won't show up in 'My Computer'
Win XP SP2 32bit
