Hi all. Looking for a bit pf advice if possible
Just put together my new system and I'm having a few teething issues.
Spec is Gigabyte x570 Aorus Elite, 3700x watercooled, 5700XT and memory is Corsair Vengeance LPX 3200MHz 2x8GB CMK16GX4M2B3200C16. Build all went together nicely apart from a bug where the bios was unusable until Windows was installed but that's another issue.
According to Thaiphoon this memory is actually Samsung B die so I was expecting it to work without too many problems. Even hoped for a little overclock. Problem is I can't get it working at 3200. I had a couple of blue screens so ran HCI memtest and got immediate errors. Everything else in the system at stock. Then ran memtest86 from usb and got several hundred errors. Reset bios to default and started again. Manually set dram voltage to the specified 1.35v, loaded xmp and tried again - lots of errors. Manually set the primary timings, same issue. Read a suggestion to start at a lower speed and increase in 300MHz increments which I did and everything is fine up to and including 3133 is error free. As soon as I pick 3200 it's errors again. Tried upping ram to 1.4v but no better. Could I have a rubbish IMC or just poor RAM?
I must admit that this is my first AMD build since the skt939 days so I may well be doing something really dumb here.
Really appreciate any advice
