Hi there,
I have been messing about with this m/b for about a week now trying to get the sound to work, but no matter what I do I get the same Error Message when I try and install the drivers. Message is:
The audio driver files do not support your computer hardware.
Note: If you installed audio software without restarting your PC, restart now, then run this setup again.
So far I have:
-Got and tried latest drivers of Asus and also other known driver sources
-Flash m/b bios to latest version
-Tried with front panel connected and disconnected
-Checked the sound is enabled in Bios
-Tried to install manually through Add New Hardware
All without any success. It does actually look like the OS is not even detecting the audio adaptor at all.
System:
Antec Fusion MATX MediaCenter Case - Aluminium Front Bezel with 430W PSU
Asus A8V-VM Socket 939 VIAKM890 M-ATX Green VGA Sound Lan USB 2.0 FSB 1000 SATA 133
Kingston 512MB DDR PC3200 400MHz CL3 Memory Module
Seagate 200GB SATAII/300 7200rpm 8MB Cache - OEM
Asus Nvidia 7300GS 256MB PCI-E
Can anyone help?
So far I have:
System:
Can anyone help?
