- 7 Jan 2009
Hey guys,
Im having right problems trying to get my sisters PC to boot Kubuntu USB or a Burned CD!
I've done plenty of these so know you have to make it bootable,and i've tested my created disks on a different system and they are indeed bootable..so i'm unsure to why this system wont boot from them!..wont even boot from an proper Windows 7 disk!
I've checked in Bios,selected both USB and CD to check for bootable media,also manually selected them to boot at startup..all that comes up is that message when you don't have no OS installed to the Drive (which is hasnt currently its a blank hard drive)
Cables are all connected snug.
Its a basic system for internet use.
Core 2 Duo E6300
2GB 1333Mhz ram
GA-G4M1-Combo Motherboard
Appreciate any help.
Its
Core 2 Duo E6300
2GB 1333Mhz ram
Its
