cant remove last PSU Pin HELP!!!!
B&W
B&W
3 Oct 2003
Birmingham
Basically hooking up my new Be Quiet 530W PSU, unhooked by ****e 250W psu, took everything out but theres this last pin that goes to the top of the case that wont disconnect, i dont want to yank it and break it so how do i remove this nice and gently.
PIC:
the pin says P2 on there, how do i take it out!!!
the 20 pin connector was a headache to get out also lol.
its pising me off it wont come out cant see a tab or anything its just a bull**** psu cable that should just come out with a little pull but it doesn't............
yes it just wont disconnect i swear im gonna rip it off at this point, going mad.
dont do that. deep breaths, get a cup of tea, sit outside and get some fresh air and avoid destroying your computer :)
i also had the same issue but it turns out that the plastic of the cheap psu made it really hard to wiggle off but i did it eventually :)
the two little wires going in havent been connected directly to the other two? so theres nothing to actually slid apart to say.
Any chance of a better pic? Cant really see anything.
This! I can't work out what you are talking about in the pic. I assume you are talking about the white plug in the middle of the pic? Looks like a fan plug or possibly a floppy power plug.
****e i ripped one of the bottom 4 cables out. 3 still connected 1 come off though, this is bull
Stick flat blade in the first arrow, the tab will then lift up and over the lock tab.
can somebody please circle what "tab" im supposed to push down, i have no idea, im getting really frustrated
