Hello,I put my PC togecther yesterday, the screen will come on if I use an adapter that came with the GPU that fits into the GPU and you attach an VGA cable to the adapter and the screen comes on, however when I plug the VGA cable into the motherboards slot the screen wot come on.
Do I need to update the drivers or something first?
the MOBO is asrock z77 extreme 4
any help appreciated
