Can't wire up the Parvum systems, Vandal Switch Power LED light
22 May 2010
Minibotpc
Here are 2 images i got from the web:
I have circled them in red to help you better understand my problem..
My power LED looks like this:
and my motherboard front panel header looks something like this circled in red again for the PWER LED:
As you can see a 2 pin will not fit in a 3 pin because one of the wires will not make contact to the front panel header therefore it will not light up. I have wire up the power connectors easily no problem but struggling to find a way to wire up the LED due to the connectios.
Please help 8pack as i know you have the same case and board.
Jay
Hi mate for power led I just cut off the end and soldered the wires directly onto the EZ plug that comes with the board.
For some reason I can't see your photos that you posted. Here are a couple of photos of a quick and ghetto fix for the problem we had with the Gene board if you haven't already fixed the problem:
Was a quick fix for us. We are looking into a cable that will fit across the 3 pin length.
Would that not damage the pin?
Haha! Proper winging it! Okay i'll give that a try then and just bend the pins.
Was actually thinking about cutting the plastic plug in half with a dremel lol
Hi, Can someone please take a picture of the Parvum Systems Vandal switch back showing the 4 wires connected so I can make sure I do it right.
(power switch) black = Com & red = NO to back vandal switch & blue & yellow to back vandal switch + - (Power LED) ????????????????????
I would imagine its very similar if not the same as dimastech switch wiring, as the majority of switches are just repackaged:
i just bought a parvum, and i am stuck on wiring the power switch. i have the on/off switch with 4 nibs sticking out and i got given a wire with 4 things on what am i meant to do with this, sorry if i sound like a noob am bad when it comes to this stuff
Thats not the problem im having mate, their is a power switch, round thing with a button that you bolt onto the case in the circle gap provided, how do i connect the wires to that?
the wires in the obove pictures should have spade type connectors on the other end.
