Are you sure.? I've saw some before I swear without
Let's see if any news at e3 if not will probably get the ryzen 5 with Vega on itx in either the kolink satellite or thermaltake cube
however it says MICRO ATx can fit however on their website its in inches at 9.6 x 9.6 which is 24.384 cm however the board ive found B450 AORUS M is 24.4cm x 24.4 cm is this just rounded up do you think lol
it fitted perfect with atleast 2 cm space at the bottom really impressed with the case unfortunately it says on the manual 2x120mm fans can go on the front but if i put 2 fans the front part of the case doesnt fully shut but this is ok because you can hide that and its still all stable
