car audio help please!
16 Feb 2006
ok so i got my 106 on the road now but it has no radio or anything in it and its kinda killing me as i want to buy a radio cassette player for it but dont no where to look or if it will fit/work in my car. i read about iso lines and positive/negative earths and im lost so if anyone could help me i'd be VERY thankful.
looking for something cheap and chearful to go in a 93 106....
The 106 should as standard have an iso connector where the stereo should be. Then its just a case of getting a normal stereo and a din adapter to get it fully running.
Check www.caraudiodirect.co.uk
You should be able to find an adaptor for your car.
From there its a case of putting the new headunit in, with the adaptor cable (which will sort out your power and speaker connections etc) and probably plugging the aerial cable in a seperate connector on the headunit.
106's come with standard ISO connectors. All you have to do is pick a unit.
not usually. Most 106's have this fitted as standard to the standard radio. You only need one if the original one has been chopped.
