don't the rac have anything that distinguishes a low charged battery from one that might be nearing end of life ? ... or, you just cant determine that in 5 minutes ?
Most battery testers these days are conductance testers, they are pretty reliable in the main, but I have noted that despite claiming to be able to test discharged batteries, they do tend to be pessimistic if the battery is nearly flat. It is always a good idea to give a suspect battery a charge and test it again before condemning it.
you will probably have to do a bit more research, which is a pain, to make sure it fits.
You make a good point about a charger. I'm only considering a multimeter because there's several situations, not just to do with cars, where it would be useful, where people have said check it with a multimeter. I'm quite keen to learn how to use one for basic diagnosis and DIY on things.
