Car borked
They said the aux belt lost a piece which dislodged the cambelt and made it jump.
Sounds odd, I don't know the 2.5T engine but the cambelt is typically covered and not exposed to the aux belts?
How does an engine just die?
Detonation, piston + valve contact, cracked block, warped deck, hydro locked, worn / scored cylinders the list goes on and on.
had this years ago on a fiesta turbo (mk3) piece had become lodged on the crank pulley and caused the jump. lucky to notice it as while head was being revalved and skimmed i was cleaning and painting the engine and noticed the rubber formed over the teeth.
still think ebay as someone would buy it for spares rather than scrap it.
Guys is it worth me buying a cheap syphon pump and trying to get the fuel out before scrapping it? It has a full tank so probably 70 litres of petrol in it or over £100 worth. A syphon pump is about a tenner.
But I have no container big enough to hold 70 litres and I don't know if it will be a horrible messy and potentially risky job to do.
Depends if you plan on buying a petrol, or have someone wanting to use it?
Can't see many buyers for 2nd hand fuel.
why dont you advertise in on ebay and say in the advert that iit has a full tank of petrol with it
Its currently on gumtree, I'll give it a day or two before calling in the scrap people.
I don't want to use ebay - lately I have had nothing but issues with the platform it is not seller friendly.
I would. There is a way to do it underneath the car. There may be a rubber hose which connects from the bottom of the metal filler hose to the tank, as that's how it is on my S-max. You can take that out and drain it all into buckets. I had to do this when I dropped the tank on my Ford S-Max 2.5T which shares the same engine and a lot of parts. I was lucky enough to have another petrol car beside it I could fill up to get rid of it all. Might be worth a look. If you have a full tank, that's a fair few buckets and cans so just be aware of that.
Dec 2019 when I bought the car (supposedly - it was part of the deal of me buying it that it was done).
Difficult to prove so you have to take their word. The schedule will probably be Ford's "every 100k or 10 years, whichever comes first". Unless you've done 25,000 miles a year since then, I doubt they changed it.
Yeah well worth it if you've got the right stuff but remember how much 70L of fuel is, it's a going to take 5x regular jerry cans and will weigh like 60kg not including the cans. unless you already have the right kind of containers or another empty car to put it directly into it's probably not worth it.
Had the same thing happen on my Leon Cupra, even though the cambelt is covered and the aux belt outside the cover. It still managed to get some aux belt into the crankshaft pulley teeth and cause enough of a jump to bend many valves. Also happened at low load, low rpm.
