[TW]Fox;12723569 said:It's a parking sensor, if it was displaying values outside of its expected range, its broken.
In that particular case yes, a sensor fault is the most likely problem. However, you won't believe the number of people (including garages) that automatically fit new lambda sensors when they get lambda related fault codes though, when there are dozens of faults that can throw the same error.
The pointing I'm making is that on board diagnostics report the symptoms of a fault, not necessarily the cause.
