- 1 Jan 2003
- Derbyshire
How is that actually connected? It looks pretty good to me, I need a new one for my truck.
I grabbed the back part from this and added it to my motorised front clamp.
Sorry to gatecrash the thread. I'm looking to replace my Yosh air vent holder as it's broken the air vents and tends to droop once the phone is inserted.
Here's another Yosh I'm thinking of buying to attach to the dash with suction. It has an extending arm so I should be able to position it as close as my vent holder.
There's an option at the top to select a £15.99 version and a £16.99 version. I might as well get the £15.99 one unless anyone see any functional difference between them?
My dash has a textured surface as seen in my photo. Will suction be fine with that?
Out of interest, what is your car?
Could be worth looking at a car-specific one? for example, I have an Audi A3 and there's custom bracket i use to fit around my vents to give a cleaner look when the phone isn't mounted.
it's from https://www.oem-mounts.com.That’s very neat! Who makes that?
Currently using a generic MagSafe air vent clip with a stabilising arm but it’s not as secure as I’d like.
If you get a model that has an adjustable lower support then you can alter the height of the phone so that the buttons don't get pressed, and accessible if needed. This can sometimes be a compromise with wireless charging though, as it may misalign the charging coils.The ones I've used in the past all push on either the power or volume buttons when they clamp. Do any of the ones you've shared have that problem?
The one I suggested has an adjustable bottom plate that you can move up or down. At it's most inward position the clamps were on my power and volume up buttons so I moved the bottom support down and it misses them now.The ones I've used in the past all push on either the power or volume buttons when they clamp. Do any of the ones you've shared have that problem?
