The Idea:
To have the front end (bulkhead - behind front seats) of a car connected to a PC for racing games.
My Plans are:
Firstly what parts I'll be using and explaining abit about them.
Logitech G25 Steering Wheel, Pedals and Gearstick
Nissan Skyline Shell (Bulkhead - behind front seats) - Explains itself really!
Xsim Software with SCN5 Actuators or Wiper Motors - This part isn't cheap unless I build something from scratch. The software takes force signals and codes from the game itself, with a PCB board connected via USB, which turns the signals into useable 'hardware format' signals. Which in turn, switches actuators to a precise movement, which moves the seat! lol
Switches in centre console for normal PC use, Turning it on, Reset, Interior Light, Motion Simulator ON or OFF. Plus some more cool gadgets.
Lovely and easy to understand I'm sure!!
It'll hopefully look something like this
How It'll Work:
The Original Steering wheel, pedals and gearstick will be replaced by the G25 set. Mounting will take a while to work out, but with the pedals already being modular it makes it much easier.
I'll take a feed off a normal button located by the gearstick on the G25, to the handbrake switch on a normal Handbrake, something that the G25 doesn't come with, but should!
The Motion simulation will take a lot of working out, but hopefully if I can keep the costs down then it will be done. The seat itself will sit on a pivot mounted directly underneath the seat, this takes the main weight of the person + seat. The actuators will be mounted behind the seat with arms reaching to the headrest, this will give best control and be most realistic.
I haven't decided on a screen yet, maybe a projector?
The car itself will use full surround sound, controllable on the centre console.
My Plans are:
How It'll Work:
be sure to take some pictures along the way! Sounds expensive too lol
