Car todo lists....
Caporegime
1 Nov 2003
Lisbon, Portugal
1) Fit Inlet Plenum
2) Solder Bluetooth Cables
3) Fit BMC CDA
4) Replace clutch
5) Replace gearbox
6) Fit uprated brakes
7) New Bonnett????
8) Fix battery mount
9) Tyres
10) Fix rear bumper sag
12) Body work, stone chips etc
12) Remove paint from fence crash
13) Claybar
14) Admire
Just thought of these off the top of my head, it'll go up if/when I order a xorst for it. Lets hear yours! :)
New gearbox, yours broken? get a TorSen in there!?
What have you uprated on the brakes, just none standard pads and discs?
MX5:
1) Sort minor bodywork stuffs + Rustproofing
2) Decent set of tyres
3) Larini exhaust system + manifold
4) Maybe some uprated suspension
5) Drive and enjoy it
1) Fit Inlet Plenum
3) Fit BMC CDA
4) Replace clutch
5) Replace gearbox
7) New Bonnett????
9) Tyres
13) Claybar
14) Admire
Might be easier to get a new car? :p
No, it's fine. But it was involved in a pretty serious accent so I bought one when I bought a load of other bits. The new one has done 30k the old one has done 60k. So whilst I'm doing the clutch I'll do the gearbox at the same time.
A TorSen? :eek: sounds illegal.
Next to me I have EBC Ultimax fronts and EBC Sports rears along with EBC Greenstuffs pads. All waiting to go on.
New turbo :mad: which in all probability means a whole new engine and 18 months off the road while I save for it.
I'm deffo doing a rear end resto over the winter though.
1) figure out why the **** the oil problem i thought was fixed ISNT fixed.
2) if 1 doesnt work, find new car
Ouch, sorry to hear it still isnt sorted tom :(
My todo is quite short;
1) Fit new airmatic compressor
2) Get some cosmetics sorted
3) Fit replacement seals to front air struts
4) Change the 4:3 comand unit for a 16:9 item
5) Road tax
MR2:
Dual exhaust back box (TTE)
Install Facelift side air vents
Get side skirts and rear bumper attachments fitted (Toyota kit)
Buy Induction Kit
See if I can sort out the millions of stone chips on the bonnet
Get scratch on rear wheel arch removed (whoops)
/edit oh, and get some clear indicators.
PICTURE of car so far
1) Replace sump tray
2) Replace front nearside wheel arch scoop flap
3) Replace undertray
4) Somehow clean the inside of the nearside light cluster glass??!
5) Get a small chip in windscreen injected with resin
6) Retrofit Aero wipers and arms.
That's it really, I'm happy that I've got everything that I considered major done. :)
Perhaps..
7) Remap and RR up to ~185BHP to eliminate flat spots.
Still debating it and trying to find recommendations though.
1) replace windscreen
2) fit door seals and window trims
3) MOT
4) buy new dashboard
5) buy new seats.
6) massive clean
7) learn to drive :P
Clio:
Wash it
Vacuum it
Save a few thousand pounds for it's 36k service
MR2:
Buy and fit some tie bar bushes
Find out where it's leaking oil and fix it
Fit new tyres
Get a new steering wheel
