Card Reader Help
1 Jan 2004
Walsall (UK)
Hi guys
Im hoping someone can help me out, ive just brought a card reader its and im totaly lost as no instructions tellin me were the 9 pin connor goes on the mother board and if i have to do anythink in the bios so it works, im not good at explaing things so i hope u get the jest of it and can help me out,
Thx:confused:
you should have some usb headers on the mobo and you will notice they have 1 pin missing from the corner as does the connector. It goes there :)
Just brought one myself the other day. Can confirm that it's a USB connection... headers normally along the bottom edge of your MB. If in doubt consult your MB Manual :)
i dont have a clue lol, i have a K8N Neo2 mobo, took side off tower and looked inside, and i see green and yellow with a 9 pin connection, but there also another 9 pin and not sure what thats for, so im hopping you canhelp
