Card Reader problem
1 Dec 2005
Stoke on Trent
Just reinstalled vista after changing mobos.
Now when i plug my card reader in it asks for a driver :mad:
It never did before, it just worked.
Any ideas guys? The card slot on my printer works fine tho :confused:
i've not used vista, but
does it not just do the search for drivers on the internet thing like XP does?
Try deleting INFCACHE.1 from c:\windows\inf\
You will need to take ownership of the file, then change the security on the file to allow you to delete it though.
There is a known issue with Vista and USB devices, this usually remedies it.
Hmm well i ended up reinstalling as i was having a few issues not just with USB.
So far, it seems to have done the trick, the only thing i didnt do this time was install the chipset driver :confused:
