card to replace 8800gtx
20 Dec 2004
Hi there - I need to replace an ageing 8800gtx (g90 GPU I believe - not the G92 Ultra one), and am looking for a card that I can expect similiar or slightly better performance from.
Not looking for mind blowing anything, machine is used for some photo editing, some video editing, and playing World of Warcraft. 8800GTX handles all of this quite well, but I am struggling with temps recently (105 deg C) and I suspect the card is gonna pop soon. Sure I can spring 50 quid for a new aftermarket cooler, but if a new card of similiar performance is going to set me back 100 quid, I probably want to go that route.
Suggestions for me please ?
thanks!
ATI 5770 will set you back slightly over £100 and generally match the 8800GTX worst case and best it by a good few percent most of the time.
Personally tho I'd clean the 8800GTX up - maybe reapply the thermal paste - you have nothing to lose and the 8800GTX is still a very capable card.
As said, try and clean the card. Since you are not looking for a more powerful card wait for the card to fail first and then you can think about getting a new one.
Have cleaned
Hi there thanks for the replies, I have removed the HSF and re-applied thermal paste etc. I have also installed the MSi afterburner set of utilities which gave me more control over the fans etc.
It only hits 95+ after very extended sessions of intensive 3d applications, or for example if I force load it with the built in stress-test in the AB app.
Currently I have the fans set for 100% from 75 degrees, the card idles at 68 degrees with fan speed at 60%
I will say this card, which is now around 3.5 years old (it was one of the first ones when they came out) has served me very well, but it has always run very hot.
I'll look into a 5770, but how would say a Nvidia 260GTX perform ?
