Cardboard grill cover
21 Oct 2002
Nottingham
Seen a few cars driving round lately with cardboard taped over the front grill. What's this some ***** efficient dynamics or what.
Old taxis always used to do it. People used to do it a lot before electric fans because the engine would heat up better in the cold.
The diesel e60 5-series has little flaps behind the grille which close when the engine is cold and open once it heats up. For some reason it's only on non M-Sport versions.
Some old cars came with them as standard. But i'd guess it'd only be Scandinavian cars generally. Not certain on the BMW's but i believe its part of the efficient dynamics where you get this feature. My dads 120D has it.
It does make quite a noticeable difference, when i have my lights on (R.E. Up) my engine takes twice as long to warm up.
Replace your thermostat then, can't be more than £15.
If your thermostat is functioning correctly, this (cardboard on the front) makes no difference to the time taken to heat up the motor, or to running temperature, or to economy. This is only done to prevent radiators freezing in really cold climates, which we don't have.
you say that its only £15 but its fitting thats the problem. For instance on my X's car you needed to take the timing belt off to get to it, which meant it wasnt a cheap job to do. Plus i got fed up trying to explain to her that the car is supposed to heat up, not run at min temp all the time, she said all her cars did that so it must be normal. :rolleyes:
Half my radiator is blocked in the winter. Thermostat is fine. It warms up faster, the heater works far better and the car is more aerodynamic. Oil working at the proper temperature is always a benefit aswell.
a lot of cars are developing active radiator shutters for similar reasons..... the death valley max load condition and bumper apertures do cause some issues in UK winter that is far from optimal for the engine.
Depends on the cars cooling system; most newer cars will have a proper bypass thermostat so that no coolant is passed through the radiator when the thermostat is shut. Older ones do not, and often have a hole in the thermostat for air bleeding but which also allows a small amount of coolant through the radiator, prolonging warm up in very cold conditions.
Handy also if your thermostat is duff.
Or if you don't have them, like on my flathead ;)
I have driven 50 miles only to find that when I reached my destination the heads were cold to the touch. Couldn't have done my fuel economy much good on that journey :(
Doesn't that just use lots of fuel regardless of temps? Can't have an automatic choke, surely? Less power generated so more right foot is the worst it would get.
