Cart check before ordering next week
29 May 2012
Dorset
Theres are a couple bits that im waiting on but thanks to a nice work bonus im hoping to be getting round to ordering this little lot next week
Any thoughts?
YOUR BASKET
1 x OcUK Tech Lab - XSPC D5 Vario Pump & EK-D5 X-RES 100 CSQ Value Combo £104.99
1 x EK Water Blocks EK-Coolstream RAD XTC 420 £79.98
2 x EK Water Blocks EK-FC670 GTX - Acetal CSQ £64.99 (£129.98)
1 x EK Water Blocks EK-Coolstream RAD XTC 280 £59.99
1 x EK-Supremacy - CPU Waterblock - Copper Acetal £51.98
2 x EK Water Blocks EK-FC670 GTX Backplate - Black £19.99 (£39.98)
2 x Mayhems Pastel - Gigabyte Orange Coolant 1L £14.99 (£29.98)
1 x EK-FC Bridge DUAL Parallel £13.99
1 x XSPC HighFlex Hose 1/2" ID, 3/4" OD, 19/12.7mm, 2m, Clear £4.8
10 x EK PSC Compression Fitting 13mm 3/8" - G1/4 - Black £3.89 (£38.90)
Total : £554.56 (includes shipping : FREE).
bit of both, the twin kfa2 670s are clocked up a bit and hit around 1200hz on boost however on reference boards and fans they hit 75c with the fans on full and it really isnt pleasant. My 3770 is already running at 4.4 on air but again is hitting around 70c and at under 1.2v i know this should break 4.5 easy if I could combat the heat a bit. Dont want to go mad just want a decent comfortable clock and not have bleeding ears
