Case Cooling Advice
29 Nov 2008
I've just purchased a new case for my upcoming upgrade.
A Corsair Graphite 780T
A few questions with regards to the cooling of this case.
The case is supplied with 2 x 140mm Front & 1 x 140mm Rear
I will be fitting a Corsair Hydro H100i V2 on the top ( 240mm radiator )
Does anyone know if the stock fans supplied with the case and the cooler are any good.
If they are not would appreciate recommendations for replacing fans on the cooler and the case, with regards to cooling and less noise.
Also what would be considered the best fan setup for maximum cooling in this case. I was thinking that the best setup would be..
2 x 140 on front pulling in air
Corsair Hydro at top - pushing out air
1 x 140 at rear - pushing out air
1 x 140 bottom - pulling in air
Thanks
