case cooling...
Permabanned
18 Sep 2006
hey,
i currently have a pandora series enermax 3030 case (not smart or lit or anything but it does the job)
it has a intake fan (12cm) and one at the back "blowing" along with a grill at the side for the GPU and a "tunnel" from the cpu fan to another grill on the side case to expel the air from the casefrom the cpu.
now this plastic tunnel basicily obstructs the back blowout 12cm fan... as it is roughly level with the CPU.
would it affect for better or worse the temp of my cpu if i removed this plastic tunnel.
COMPETITOR
this is the case so you can see for yourself...
hope links to external companys are allowed - they are not
thanks for reading.
~edit~ sorry, didnt see the cooling section :confused:
:cool: Hi,
I think that you may have a sim type case 2 mine :D all I would say is YES remove the plastic tunnel vent and make a few adjustments 2 your setup and you should be ok :)
If you are in dought about air flow :confused: you can use them sented sticks that give off smoke and see how your system is working without causing any damage ;)
