Case fan adapters and layout
27 Jun 2009
Nottingham, UK
Hi there, i'm not entirely sure if this is the correct place to post this, I thought this was probably a better spot than cooling however.
Anyway, my pc noise has been driving me mad so i've decided to invest in some kind of fan controller.
The fans I have are all 4 pin molex but the fan controller I like (according to the review) uses 3 pin connections.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-021-AK&tool=3
I created a diagram with my current layout, and then a blank part to be filled in with your idea (if anyone fancies it),
http://img522.imageshack.us/img522/4719/gazpcfans.jpg
the large fan on the front isn't really an issue because its larger, it's just the 3 smaller ones, when I turn my pc on it sounds like a Harrier jumpjet taking off
I'm just a bit confused over how many adapters i'd need, whether i'd need 1 for each fan or whether I could get away with 1 adapter on it's own, but i'm not sure on power requirements of that
http://www.overclockers.co.uk/showproduct.php?prodid=CB-007-GE
I thought maybe these would work.
(edit ok i just saw they were out of stock T_T')
I realise i've waffled on and this thread comes close to breaking the guinness world record for the largest noobish post ever but thank you for your time.
- Gaz
