Alright folks,
So basically I'm running the following -
3 x 120mm front intake
1 x 140mm exhaust
2 x 120mm on the H100i
I'm looking to replace them all with quieter options as these all seam pretty loud. I have a BitFenix fan controller which will control all the fans except the H100i ones which I'll run off the H100i itself.
My question is do I "need" to be getting PWM fans? It appears I've ordered normal ones and I'm not 100% sure if I can control the speeds of these? Will Corsair Link not change the speed of the H100i fans if they're not PWM?
Many thanks
1 x 140mm exhaust
Many thanks
