Hello, I have a few questions about the molex plugs that have the case fans on and the PSU molex wires.
I have the PSU and there are what I belive to be two separate thick wires that both have multiple molex plus on them, however one has a 4pin plug on the end of one, so I am stuck on which one to use?
Is the one with the 4pin plug on the end for when you attach the case fans onto the molex plugs then insert the end of the cable with the 4pin plug on into the MOBO for bios control over the speed? and if so what connecter does this go into on the MOBO?
Is the other wire with only molex plugs on them for if you want the case fans to power straight from the PSU at the max speed?
any help appreciated
