Case Fans Question
Ah, good stuff. If you want the taskbar to behave a bit more like vista/XP, you can right-click on the taskbar > properties, for "taskbar buttons" select "never combine" - thats what I use.
Yea, best to stop now - it should be OK for short term general use as few application stress the CPU as much as OCCT, but I would certainly invest in a quality CPU cooler ASAP. It will not only get your temps down, but make everything much quieter and allow you to try your hand at overclocking.
That voltage doesn't seem too bad, however if you want to try reducing it incrementally (running OCCT for a while every time you change it) then you will be able to find the lowest stable voltage for your current configuration. This will run cooler and use less power, but takes a bit of time.
