Case Fans Required
23 Nov 2009
Im after 3 fans for my case. Would love it if they are black/grey or blue to go with the insides of my case, but not required.
  • Need 2 - 120mm or 140mm Fans
  • Need 1 - 120mm Fan
So in total 3 fans.
Scythe s-flex. There are more sensible choices, say the slipstream, but I'm using the s-flex as case fans and couldn't be happier with them.
Noiseblockers (the expensive ones) THE best especial if run off a fan controler or 7v mod
But expensive - I have a S2 in my pc (it's the only fan I own) and I'm a quiet pc freak :D
If you can use two fans get the NB's
If you need the airflow of three the S-flexs or slipstreams are better value for money
