- 27 Jun 2005
what are the best vfm, low noise, good cmf case fans you can get?
cheers in advance
cheers in advance
( reme,ber to put it full blast)Runningkid said:Delta fans are quiet( reme,ber to put it full blast)
TaKeN said:Panaflo Fans are ace to be honest![]()
TaKeN said:ive got three..
cant think what code they are now..
NMB-Mat something, but i switched them from 7volts to 12volts.
Now each fan pushes 116cfm @ 42db
Noisy to be honest lolz, but i wear my headset and it masks it![]()
Prob not L1A's then (69cfm/30dB @ 12v, 41cfm/<19dB @ 7v)
Foehammer2003 said:Looking outside the box a little here, but as the ambers arent cheap as chips, would it not be worth considering getting a cheap fan controller and soft dampening mounts sold here then you have the choice over CFM/Noise ratio. If money is no object then AcustiFan are good cfm to noise (oil dampened bearings).Not that the aforementioned are expensive
jellybeard999 said:120x25mm D12S12
VERY cheap if you can find em, OEM versions of the Nexus fans, which spin slightly faster...
Mikebert4 said:WTB!
I'm slowly getting better fans for my system... sourced some tasty blue-LED Mag-levs cheap on a certian online auction site... 22dB and 71CFM
Mikebert4 said:well, the fan controller is a good idea... great to be able to slow everything down an leave your PC folding overnight... The vibration dampening mounts IMO don't do anything for noise, i've used anti-vibration tape (stuff they use on aircraft instrument panels - tis verrry good) on my fans before now and barely noticed a drop in noise at all, if you exclude the fact my MoBo tray used to rattle and now it doesn't.
If you're using Oil damped bearings, be wary of fan controllers as those that use PWM (pulse width modulation) have been known to distroy these fans, spewing the oily goo everywhere... (ask people about using the freezer64 Pro with PWM) doesn't happen to all fans, nor all the time, but it's a risk..
Mag-lev fans are a geat noise-CFM ratio, though they're not cheap and they're hard to get hold of (i would linky but i'd get in trouble for linking to competors.. not sure if OCUK sells 'em).
I've even tried removing all the outside rim off one of my fans, leaving just the motor and two mount holes... not worth the effort either, noise dropped a little but CFM plummeted
IMO, bite the bullet, pay the extra and get yourself some silent fans such as Akasa Ambers or panaflows.
