Case fans
30 May 2011
I recently bought some Antec Tri-Cool 3-Speed 120mm Fans from OCUK - they were on offer but didn't come with any screws (is this usual? Seems a bit cheeky). Anyway, what can I attach them with? Do I need to buy special screws? None of the screws that came with my case seem to fit.
Got the same problem as you mate, you really need to buy some fan screws or fan pins like this - http://www.overclockers.co.uk/showproduct.php?prodid=FG-053-AK&groupid=701&catid=57&subcat=795.
Id go for the akasa pins, they help with vibration and they dont mark the finish on your case.
