Case Fans
17 Nov 2011
Can someone suggest me the best fans which will reduce the heat and silence isn't the problem but not too loud will be good enough and I don't want LED fans please, 2x120mm and 1x92mm fans
This is supposed to be quite good, might get one soon to try out.
Ive got this Which pushes a LOT oaf air out of the case, and is only loud because of the amount of air it can move, but it's out of stock at the moment.
I wouldn't say the best, but from what iv'e read, it is good.
People rave on about these too, but theyre pretty expensive and used for watercooling radiators :p
