Case for £30-£50.
12 Dec 2005
I've decided I need a new case since mine is now battered and the fans on the side are hanging off. :p
Please could someone suggest a case within the price range of £30-£50?
Thanks
Cheers mate.
I've got the Zalman Z7 now. It's been a good case. The Z9 looks appealing. The issue with the Z7 was cable management was a PITA. Hopefully that has changed with the Z9... I'll have to look at some reviews. :)
Any other opinions would be appreciated.
Cheers
Just looked at a review for the Z9 and it seems like the obvious choice. Cable management has improved from the Z7 and you have a lot more options for air cooling.
At only £45 it seems to be a very good price also.
Is it a good option then? :)
Its a good option, plenty of fans as standard, a little fan controller and temperature probe/display.
Zalman is a great case for £45 - £50, and as above good options for cooling and the 4 free fans are handy if you don't plan on adding your own.
Build quality isn't amazing though IMO, but I do really like the case and cable management is fairly good too. :)
