They do not, at least not officially, benchmarks like firestrike and the similar will do 3/4 way natively. You can actually get 3/4 way SLI working in some games by using Nvidia inspector and using the Firstrike profile to trick the game into believing 3/4 way SLI works. It's hit and miss though and in my experience, does not always work great or the micro-suttering is heavy, even with G-Sync.
I expect though a large number of people going 3/4 way configs use them for applications which do not use SLI mode which still work fine. So rendering, deep learning, mining etc.
Corsair Air 540 (458mm tall) or Corsair Air 740 (510mm) with 8 expansion slots, depending on your motherboard's first PCIe slot, otherwise a case with 9 slots. Building in it is very easy.
