Case for RX360 and EX240
12 May 2010
West Bromwich
I have to do the 12 month maintenance on my loop this coming December and would very much like to have the RX360 that is outside of the case (Haf-X), inside.
Couples of questions:
- Which cases out there support would support an RX360 and an EX240 for the cpu ?
- I noticed there were no RX360's for sale on OcUK, but when I checked on XSPC's website, they are advertising a V2 of the radiator. What are the differences. Was there a design fault in the original?
Thanks.
Corsair Carbide 540 might fit the bill. Can fit a 360 in the front and 240 at the top.
No idea about the V2 radiator though
Switch 810 fits 360 in the roof and 240 in the bottom if you take out one of the hard drive cages.
If you didnt mind a bit of light modding, could just make sure the bay enclosure didnt block the fill port and then add a bit of hosing to the fillport with a stopper at the end. Then you can fill it up using the bit of hosing. You could add a tiny tube reservoir in the back compartment out of sight and use that to fill up your loop too.
