Case for watercooling
15 Jan 2008
Manchestoh
I'm planning on making a new watercooled PC, but I'm not sure what's the best case to use. I was originally planning on using one of the beautiful Silverstone cases, but due to the insane cost, that's pretty much out. Which case would take a 120.3 rad with the minumum of fuss (ie, not having to cut holes in it, which I don't have the tools for)?
Can't afford a Silverstone (as I said) and I don't want external rads as I *will* smack something against them and either break something or pull a tube off sooner or later.
Any decent water-cooling specialist will cut a case and fit a radiator for you.
How much extra does this cost usually?
Also how much is the cutting equipment and how hard is it to use if I want to do it myself?
I usually pay my guy £30, but assuming you've had it shipped direct to the specialist for cutting, you then need to factor in an extra £10 or so to have it shipped back to you.
