Case for watercooling
14 Feb 2011
Scotland
Hey am interested in what case would go well with a XSPC Rasa 750 RS240 mounting and installation wise, preferable not overly expensive, toolless and if at possible with side window or mesh cheers. :D
The CM 690-II's claimed ability to support 2 x 240mm rads (one top, one bottom) is fibbing a bit. From personal experience, I know that to fit a 240mm rad in the bottom your PSU must be no longer than 160mm and the rad must be no longer than 280mm (and even then it's an extremely tight squeeze, rendering modularity in a PSU redundant as you have zero space to change cables). This rules out the use of top-end PSU's (a 1000w PSU is typically 200m+ in length) and since water coolers tend to want high-end, power hungry components (e.g. you're watercooling because you're overclocking) you would probably want a 1000w PSU - which you can't have in this case with a bottom mounted radiator.
So chances are you'll only be mounting a 240mm radiator in the roof. If that's the case, you might as well go for a full tower case like the HAF 932 (also Coolermaster) or the 800D Obsidian (Corsair) that would allow you to mount a 360mm rad in the roof. Thus you can have a 360mm rad (good enough for most loops) and still mount a long (and thus powerful) PSU in the bottom. Additionally, the 800D has a rather handy 120mm fan mount on the lower compartment wall, with which you can use a bracket to mount a pump. I find bay reservoirs that are independent of the pump are easier to work with. I always worry about the seal between bay res and the disassembled pump, ever since my XSPC+DDC combo fiasco (the pump melted).
So my recommendation is the Corsair 800D.
i kno the lanboy air tower has space on top of the tower to support a single/dual rad plus most all in 1 kits will just simple go straight onto ure 120mm fan at the back which most ppl have :),plus u said mesh or window,well theres plenty of mesh on a lanboy air tower which has great cooling capabilities,from what i can make out is this XSPC Rasa 750 RS240 ,its a double sized rad so lanboy would fit it perfect man with grommets already in place to put ure hoses thru bud :)
Lancool PC-K62 or CM 690-II..
I would recommend the CM 690-II but not the K62 for that watercooling bundle. I have a K62 and with a bit of modding I was able to fit a slim 280 rad in but I doubt (other than externally) there is anywhere else you could fit a rad.
