- 4 Jul 2006
Heya guys I am having a really pain in the ass problem.
It comes down to 2 things, well 1 thing in particular. The PSU.
I have the Coolermaster HAF 930 case along with a Corsair VX 550W ATX Power Supply and the way the cable is made means I cannot have more than 3 hard drives plugged in at a time due to the wierdness of the cable it bends the SATA connection on the HDD at the slightest move and I hate to think if it does it when the case is closed.
I will show you a video, forgive the recording I used my camera but it should outlay the problem.
The major problem other than the amount of protection on the side is that as well as bending I will have to rotate and that is impossible.
I was hoping for any ideas or recommendations for a REALLY flexible PSU because atm there are 3-4 SATA power leads being unused and 2 hard drives I wish to install and run in my case in addition to the 3 I already have in there.
My attempt at rotating so its not sideways didnt go as well as I had hoped but I will link that one first, if it is too small you can view the other one underneath it.
On youtube it seems this one is rotated already which didnt happen with VLC or AVS Video Editor ???
Anyway, hopefully you get an idea of what my problem is...... I Hope.
