Case ideas for Phase..
1 Feb 2006
Worcestershire
I'm looking for a new case now I have my phase unit, as the Antec 900 I have isnt suitable.
The evaporator pipe comes out of the bottom of the phase unit quite far back so I'd need a case with lots of room at the bottom left corner (looking at it side on) So I can cut myself a nice hole for it to come through.
Also the PSU needs to be mounted at the top of the case.
I've looked at some Lian-Li cases P60 Plus / P7 also some of the bigger towers but they get quite expensive.
What would you recommend ?
