- 5 Jul 2007
Asus motherboard running Asus Aura...
I see four connectors on the Asus motherboard -
1X - 4 pin 'RGB_HEADER'
3X - 4 pin (1 blank) 'ADD_GEN 2'
I need -
A short rgb led strip to go across the top of the case to light up internal components to check fan spin as no fans are led. Colour/brightness adjustable via Asus Aura (currently controlling the 1080ti onboard leds so dont want additional software).
Yet I see talk of 3 pin connectors, not 4 ?. What's the difference between RGB header and ADD GEN 2 ?. Then there's 3pin 5v Y ARGB adaptors ??. If someone can point me to a short rgb color and brightness 'Aura' controllable rgb strip that will plug directly into the motherboard rgb or gen2 connectors I'll be forever in your debt....
I need -
