Case lighting
2 Dec 2004
Under The Desk, Wales
People, what is the best / cheapest way to add lighting to the inside of the PC. Years ago i used a Cold Cathode.
I want a nice 'Blue' light inside the PC as i have a window in the side. Daughter loves the idea of having a 'Blue' light in there. Any ideas would be superb!
Thanks
Bitfenix do some led lighting strips which are low power and pretty good or for a bit more you can get nzxt hue which will give you a range of colours to choose from.
I like Cold Cathode to light up my case will a led lighting strip give a uniform lighting that the CC does.
Do we have any idea when (or if) the Revoltec Cold Cathode stuff will be back in stock?
Personally I got 5m rgb strip with controller and 12v power-supply and put it in my case around 10-15 pound on bay or rainforest
