- 20 Oct 2008
Why wouldn't you space the entire radiator down a couple of mm rather than butchering the case?
It's at it's full depth, I can't push it any further sadlyWhy wouldn't you space the entire radiator down a couple of mm rather than butchering the case?
A totally round one is good for cutting in to the right depth of cut you want.. A half round one is then good for widening out and smoothing out the original cut in.
I wouldnt use the nail file size sets, they can break under moderate force. A medium size set would be better.
It's at it's full depth, I can't push it any further sadly![]()
I never considered having the fans up top, mainly because I wasn't sure if I'd lose some cooling ability and also I wanted the white fan LEDs to light up the case internals?Space it between the radiator and the bracket. A few suitable washers, or some sort of gasket/spacer, and maybe some slightly longer screws and you'd be done.
You could also decide to put the fans between the radiator and the bracket and space it down that way.
Out of curiosity, what did you end up doing in the end ?
bought an Air Cooler![]()
