Case/Psu Supply question
Permabanned
13 May 2011
So i was considering getting a new case, possibly a lancool p62 or HAF922. But then i ran into this on ******: http://www.******.com/product/220862
So my current system is a 500w OCZ stealthstream 2 and a ****ty xigmatek asgard case, would that PSU and case be an ok upgrade?
And would you guys consider the coolermaster GX 650w to be a good psu noise and performance wise?
System:
AMD Phenom ii x6 1090t @ stock
ASUS M4A78Lt-M
Gigabyte GTX560ti SOC
You can't link competitors, just link to the items here or a picture from google to show us what you're after :).
Edit: Coolermaster PSUs aren't the best but they're not awful. I'd say for now your current PSU will do the job fine until you upgrade your other componants.
If that's the Coolermaster CM690 II Lite with Coolermaster GX 650W PSU then I would give it a miss. The GX 650W is not a great PSU (have a look here) and with your current system I would suggest sticking with the 500W Stealthxtreme 2 for the time being (so long as you aren't changing your main components much) and just upgrading the case.
Between Lancool and CM 690 II, whichever you prefer really. both are good cases, then it's a matter of preference / budget. If you like the red interior of the PC-K62, or the windowed panel, that's what I'd go with. If yo don't care, the 690 II. I'm not so keen on the HAF myself. Doesn't seem to have as good cable management features, and hasn't got a finished interior. Seems like an older case design.
