Hi All,
I currently have an Antec Twelve Hundred v3 case which I am looking to replace with a smaller case which has similar or better airflow.
I have heard good things about the following cases:
https://www.overclockers.co.uk/lian-li-pc-o11-dynamic-midi-tower-black-window-ca-76s-ll.html
https://www.overclockers.co.uk/cors...-cube-case-black-cc-9011030-ww-ca-143-cs.html
With regard to the Lian-Li 011 Dynamic can anyone advise on how best to setup the fans E.G. how many to use, intake / exhaust configuration?
The case will need to be able to fit a Phanteks PH-TC14PE CPU Cooler and a Zotac GTX 1080ti amp extreme. The system is currently air cooled however I would like the case to be able to support an AIO when I eventually decide to upgrade.
All advice / other case suggestions are appreciated!
