Ok, firstly specs are in the sig.
Minus the case which currently is a Thermaltake Soprano w/ window.
The current problem with my setup is the x1800xt is long and covers enough space to stop the use of 3 x 3.5 slots.
That leaves me 2 external and 3 internal. Since they can get hotter next to each other, i'd prefer to have them spaced. I also intend on adding a 4th sata drive for further storage, but thats for another topic.
I'm budgeting myself at £120, don't mind hitting £130 as long as that includes delivery.
I need a case thats either.....
a) long enough so that the vid card doesnt block access to the 3.5 bays.
b) has outward facing bays, and lots of them, again not wanting drives next to each other.
c) if the two above can't be suggested then a case that can cool the drives better.
d) alternate suggestions.
Bear in mind i don't want anything that sounds like a wind tunnel, 120mm fans are definately preferred.
Window is a must, i like my UV reactive.....
I've seen a few cases that look suitable, but i'm sure theres a few people here that have cases that will cover my needs, so recommend away if you can.
I know its a big ask, but if you don't ask, you don't get....
