- 31 Jan 2012
Hello
My SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply,
https://www.overclockers.co.uk/showproduct.php?prodid=CA-005-SF&tool=3
arrived today and while it will fit with a tight squeeze its a little long and heavy for my crappy current Cooler Master case.
Can anyone recommend a good case that can accommodate this PSU for around £80?
It seems I could make it fit but I'd have to drill some holes in the top of the case or something as I cant see just the back psu screws supporting its weight.
Also is it safe to just straight swap motherboards etc also to another case?
Thanks!
Thanks!
