- 23 May 2006
- Blythe
squiffy said:Plug ATX power cable to the PSU, switch it on by the wall, but have the PSU power cable to off. It'll be grounded, but it's safe to connect things ie mobo ATX power cable, HD, etc.
Got any better pictures of mobo and PSU? Is PSU standard ATX, or fixed to the case?
Thermaltake VC3000BWS looks pretty good.
The PSU connections will go in the same place as long as you're using the same components.collisster said:My PSU is a Hiper Type R 580W Modular ATX2.2 PSU if that helps whoever was asking.
Does every connection need to be in the same socket, (if you know what i mean)
Thanks
edit: I've had a look at the antec super lanboy, I dont like the waffle on the front of it. anyways thanks
orderoftheflame said:wall switched off i hope you mean![]()
(sag-okia at zen.co.uk)james.miller said:
have you tried updating the firmware?
