Case wiring! Positive or Negative?
4 Feb 2004
Hi guys, with LED connectors and switch connectors, on the black female part you plug into the board, they have on one side a small arrow on the plastic, does this mean positive or negative??
Cheers.
The coloured wire will be positive - I think. Seriously, just try it and see. With the switches it shouldn't make any difference, and with the LEDs it will either work or it won't. :)
Thanks guys, my main worry is for USB connectors though, the manual rattles on and on about if they are wired up wrong they may damage the USB device.
Do a search on USB connector pins and you'll get what you are after. It's fiddly, but quite straightforward. And yes, if the motherboard doesn't have a poly-fuse and you connect them the wrong way round, you'll fuse the board and make that USB port unusable.
