I7 4770K (At 4.4mhz, i think)
Gigabyte Z87X-DH3
Coolmaster silent pro 900 (or was it 800)
Thermalright Silver Arrow SB E Extreme CPU Cooler
16Gb Corsair Vengance ddr3 @ 1333MHz
Gigabyte Auros GTX1080Ti
Hi Fellas
Been watching far too many Gamers Nexus Videos regarding cases and there comes a point when you just gotta push the button.
Looking for a case with good airflow, mesh fronted, preinstalled fans (can add an exhaust if not supplied)
Price £50-£250 good quality
Will be upgrading my system later in the year when the dust settles, say upgrading, the only bit i'm using is the 1080ti above,(will not be vertically mounting) not sure on the Motherboard, CPU etc yet. Also not sure if will be using a AIO or Air cooling for Heat sink so need the space for both. The Coolermaster below is a bit wide @ 250mm, would not be able to accommodate any bigger than that
Couple of options below i like the look of, different end of the price spectrum, anyone rate these, or have one. Any other suggestions in my spec?
My basket at Overclockers UK:
Gigabyte Z87X-DH3
Hi Fellas
