*****Caselabs sth10 review*****Picture heavy !
2xquad rad stands for 120mm fans
your going to need these :)
These are for the tubing to go into the top compartment or bottom compartment.
that should be all you need for now unless you want some other parts.
As the Americans would say, you're awesome.
If I'm not mistaken, the white cages comes with the case.
Also, did you select mesh on top or the 120mm mesh?
Not sure what you did (can't see it in photos) but maybe the fan backplate is a bit overkill. There's the option of hex mesh so maybe better to go with that.
So, when are you gonna hook her up with all that yummy w/c stuff?
Any pics with the window mate ? how much of the interior can you see with the panel on ?
I've a few ideas that i think would look pretty impressive if ..and thats a big if i can afford this case ;)
